2004 XC70 - Steering Creak!
Hi All,
I have a 2004 XC70 with about 113k on it. I bought it about 6 months ago with 98k for about $3800. I've put some (a lot) of money into the front suspension and I thought I was done, but in the warmer weather (could be a factor, but it started this month) I now have a creek at slow speeds like when I pull into a parking spot or turn a corner slowly. It's only activated when the steering wheel is in motion and I don't think its related to the power steering as I know what that sounds like. Here's the work that has been put into the vehicle as far as front suspension goes: 32k: Stabilizer bar links Strut mount (s)? (Carfax doesn't specify) 54k: Inner tie rods Left tie rod end 98k: Lower ball joints Lower control arms Left CV shaft Right CV shaft 107k: Right tie rod end Right front axle assembly Any ideas as to what this could be? Thank you!! |
The steering column goes through the firewall/floor. There's a rubber seal which can take a shot of silicone spray (or some better suited lubricant).
This is only one suggestion. A recent thread on this subject (the seal itself) on another board brought this to mind. |
Hi Georgeandkira,
Thank you for the reply! I think we read the same thread.. I hit it with a shot or two of white lithium a little while ago and it didn't seem to fix it unfortunately. Thank you again! Matt |
If you can get the noise when the car is sitting still and the steering wheel moving get a helper to turn the wheel and start tracking the noise down.
Harder to do if the noise is only there with the car moving and the wheel turned. |
