284: ECM-640A Camshaft Reset Valve. Faulty Signal. 4.6ohm on solenoid?
Old Jul 27, 2015 | 09:10 AM
frknvgn's Avatar
Default 284: ECM-640A Camshaft Reset Valve. Faulty Signal. 4.6ohm on solenoid?
I've had this code plaguing me for a while. 2.4na 115k miles
Symptoms:
rough idle, more common with cold engine or when warming up. RPMS drop and engine sounds like a diesel or I've got a really lopey cam.
I can correct idle by raising the RPM to near redline then letting it drop. No drivability issues except for a little slow starting from a stop.
First time this happened was after I had got a sudden studder from my engine in a high-rpm sharp right hand turn (remember VVT solenoid is top right of engine). I was winding up 1st gear around the turn out of a parking lot and it felt like there was a rope behind my car and it got a solid tug backwards. I think I starved the VVT solenoid of oil and it brought the timing back, causing this 'studder'. The check engine light was immediately on and has been on most of the time since.
What I've done:
removed VVT solenoid and cleaned solenoid with carb cleaner, twice. Even let it soak for 5-10 minutes. Blew out with air hose. No improvement. Checked MAF sensor, checked out good. Cleaned intake valve (butterfly). No improvement.
I measured 4.6 ohms across the coil in the solenoid. FWIW, from what I read about the XC models, they have an exhaust solenoid too and it's supposed to be 3.7 ohm when cold.
Can anyone verify what the resistance should be for the 2.4na intake solenoid?
Thanks!
Old Aug 27, 2015 | 07:28 AM
frknvgn's Avatar
Oooookay well figured this one out on my own. VIDA says between 2 and 11 ohms, which is a rediculously large range, but that's what it says. I used a bluetooth OBDII sender and an app for my phone to watch timing and in fact, timing went off when my idle went poor, typically higher. Though the app was probably watching ignition firing timing, not mechanical valve timing. Either way, it was reason enough, compounded with what my DICE was telling me to replace the intake solenoid. The new solenoid measured in the high 3 ohm range and i bought a new gasket, which had a metal mesh filter installed on the oil delivery orifice. Everything has been running fine for about a week now.
Rdhcincy
Nov 27, 2023 12:04 AM
s60-owner
Jun 17, 2015 06:38 AM
Metal Mickey
Dec 17, 2013 10:54 AM
Rdhcincy
1998-2000 model year V70
May 14, 2012 01:29 PM
s40volvo
Sep 26, 2011 10:06 AM
