P2 Double DIN?
Old Jul 7, 2022 | 01:42 PM
Road_Carver's Avatar
Question P2 Double DIN?
Hi all,
I have been looking for a nice double DIN face plate for my V70, I can only find the ones with no cubby hole and offset to the right, does anyone know where I can get one that either has the cubby hole or is centered?
Thanks!
Last edited by Road_Carver; Jul 7, 2022 at 01:52 PM. Reason: Can't get sig to show
Old Jul 8, 2022 | 01:33 PM
IPD and FCP both sell the face plate for about $135. It doesn't have the cubby but is offset slightly to the right - probably to give the depth required for an aftermarket unit.
https://www.ipdusa.com/products/1047...BoCkYcQAvD_BwE
Old Jul 18, 2022 | 12:05 PM
Tinkerbell's Avatar
If you push on the panel to the left a cup holder should pop out. I have that on my 2001, I'm not a cup on the dash sort of person so I changed it. If you can find a unit that has the cubby at a junk yard, you can swap it for the cup holder. Once you have it out of the dash you'll see that the cup holder will just slide out and you can put the cubby piece on.
Old Jul 18, 2022 | 02:50 PM
I already have the cubby, I am looking for an aftermarket plate that will retain the cubby, or center the opening...
Old Jul 20, 2022 | 06:57 AM
Dingus1's Avatar
Originally Posted by Road_Carver
Hi all,
Thanks!
They are offset to the right because of the plastic molding behind the radio. You would need to do a significant amount of plastic cutting to make your radio centered in that area. You can potentially pick up a normal plate (offset to the right) like you are seeing and retro-fit your cubby in there. I had a cup holder in my car, not sure how the cubby attaches.
Old Jul 28, 2022 | 08:01 AM
Dave_in_MD's Avatar
I am waiting on one to show up, it is for a 04 and previous P2, you could make it work but you would have to back date the entire center stack.
https://www.amazon.com/dp/B07R9SL7NY?psc=1&ref=ppx_yo2ov_dt_b_product_details https://www.amazon.com/dp/B07R9SL7NY?psc=1&ref=ppx_yo2ov_dt_b_product_details
Picture in ad is upside down.
Deshawn324
Jul 21, 2012 11:46 AM
Kat2012
Jun 25, 2012 12:12 PM
bhannkb
Jan 23, 2010 04:31 PM
ddub
Aug 31, 2008 07:07 PM
MattB850in
Mar 12, 2008 08:52 AM
