power side mirror question
Hopefully this is the right place.
I got both side mirrors from a 2008 V70 from the auto recycling yard. I want to use these mirrors on an older car I am restoring. The question is can the mirror motor be used directly? Meaning without going through the door module. The turn signal and bottom door light leads I have identified. So I can use them. I would like to be able to use the mirrors if possible. I have downloaded a wiring diagram that mostly matches the wires of the mirror. But it doesn't identify what wires control the mirrors movement. I have tried several different wire combinations with no luck. My guess is that these mirrors only work through all the different modules. Thanks. AJ |
Originally Posted by AJinAZ
(Post 534692)
https://cimg0.ibsrv.net/gimg/volvofo...b40d90dc87.jpg https://cimg8.ibsrv.net/gimg/volvofo...dfaaeb3442.jpg . |
Thanks. That helps a lot. I have a couple of mirror switches I can try setting up. Testing with only two wires before explains why it wouldn't work. And your wiring diagram looks just like the V70 diagram I have. Now I have something to go by.
Thanks again. |
| All times are GMT -5. The time now is 09:42 AM. |
