V70 2005 Codes O2 sensor dealer can't fix
Old Jan 17, 2013 | 08:12 PM
Ajelgatian's Avatar
Default V70 2005 Codes O2 sensor dealer can't fix
I have just purchased a 2005 V70. The engine light is on and it codes O2 sensor. The dealer has had it for two months and can't fix the problem. They have even tried replacing the computer. They disconnected the O2 sensor and said here's your car back. Our master mechanic has better things to do than work on a problem that can't be fixed. I did not purchase it from the dealership. Any suggestions would be so appreciated.
Old Jan 18, 2013 | 04:19 PM
MaxOrbit's Avatar
The first thing to do is post up the actual codes then go from there. By disconnecting your O2 sensor they've guaranteed you'd being getting poor gas mileage ,power and maybe even destroy you CAT.
Old Jan 18, 2013 | 05:51 PM
ES6T's Avatar
Is this a Volvo dealership doing that? Or some used car dealership?
Old Jan 19, 2013 | 10:16 AM
Ajelgatian's Avatar
Default Max orbit
Ok as best as I can tell the tech wrote on the initial paperwork, vehicle will CCEL A3 check engine CINSP. A3 Volvo multi. Vm 315 11-14. They have replaced the MAF tried replacing the ECM didn't work. Replaced frontpressure sensor o2 sensor. Still running rough. All wiring has been checked. We bought it used a Toyota dealer and have been working with Volvo to fix it. It has come to light that the previous owner had problems too. I don't know what these codes mean but they are on the statement too. 05d21, 222w-22010, 19 74w-2030. Sorry if this is confusing I am posting this for my husband and I am a little inept.
Old Jan 19, 2013 | 10:17 AM
Ajelgatian's Avatar
Yes it is the dealership. We have spoken with headquarters and they can't help us unless we choose to go back to the dealership.
Old Jan 19, 2013 | 06:10 PM
MaxOrbit's Avatar
The codes you posted don't seem to be anything that I know of.
Most OBD2 codes are P xxxx (xxxx is a number)
A volvo specific code should be ECM-XXXX( xxxx is a number.)
Maybe someone else has an answer.
Did they remove & check the plugs or verify the coil packs are all working?
ngdo
Feb 7, 2026 07:38 AM
drenman
Nov 29, 2016 07:35 AM
theotherpilot
Jul 10, 2009 12:28 AM
Volvorator
Mar 15, 2007 10:37 AM
cranky
Aug 5, 2005 09:46 PM
