-   2001-2013 model year V70 (https://volvoforums.com/forum/2001-2013-model-year-v70-55/)
-   -   V70t p0342 (https://volvoforums.com/forum/2001-2013-model-year-v70-55/v70t-p0342-89663/)
Josho Aug 22, 2016 08:16 PM
V70t p0342
02 Volvo V70 Turbo. Check engine light is on. I'm getting a code for a camshaft position sensor (P0342). Sometimes it takes the car a few times to crank, otherwise it runs flawlessly. Seems like an CSPS issue but I would like to know for sure before I go throwing parts at it. Is there any way to further troubleshoot this issue?
Josho Aug 24, 2016 05:41 PM
I replaced the Camshaft position sensor; made no difference. I also pulled out the crankshaft position sensor and it looks new. Wiring looks good.
I hooked up my scam tool and looking at the real time @ idle, the SparkAdv was at 11°. Shouldn't this be around 15°? Leading me to believe that it may be off a tooth. Any thoughts?
Josho Aug 31, 2016 09:12 PM
Bump..
Josho Sep 2, 2016 01:14 PM
Any advice on this??
pierremcalpine Sep 8, 2016 08:00 AM
sounds like timing might be slightly off...was any work done prior to the code appearing?
Josho Sep 8, 2016 03:08 PM
The code was there when I bought the vehicle. I'm going to check to see if all timing marks line up.
Josho Feb 14, 2017 06:36 PM
Timing is not off. It revs up as it should and drives fine. Every once in a while it will have a surge at idle. But it still has trouble starting. Any suggestions?
Josho Feb 17, 2017 05:25 PM
This is my first volvo and I'm totally out of my own suggestions. Anybody have any??
