Washer pump problems
i recently bought a 2004 and have had some problems with my front and rear windshield washers. i have already replaced the front nozzles which helped some. i took off the pump today and cleaned out the screen leading to the reservoir. also disconnected the wet lines and submersed the pump in a mixture of water and cleaning fluid while turning it on spray mode for the front and rear to try and clear/clean it out. looking in the hole where fluid comes in the pump it looks fine and i can hear the motor running in both modes. i was by myself so was not able to see how much pressure there was while running it. once
when i put it all back together the front works a lot better now but the rear still isn't work at all. the only thing i haven't done for the front is replace the two washer Ts that come before the nozzles. is there a washer T for the rear sprayer that may be clogged or does the line from the pump to the rear sprayer go direct? any help? thanks.
