2010 xc70 p045500
I plugged in my scanner to check for a cyl 6 misfire p030600 and found this code as well and I cannot even get it to clear. There is no engine light either looking for help or ideas thanks
Volvo DTC ECM-P045500Make:Volvo Code: ECM-P045500 Definition: Evaporative Emission System Leak Detected (Gross Leak/No Flow). Description: The engine control module (ECM) checks for leaks in the fuel system by measuring the current consumption of the leakage diagnosis pump when pressure is applied. If the current consumption measured under pressure does not change in a specific way or a certain pressure is not obtained in the system within a reasonable amount of time, the control module assesses this as a large leak (leak larger than 1.0 mm) from the fuel system. See Design and Function for more information. The diagnostic trouble code can be diagnosed when leakage diagnosis is running. Cause:
