automatic key fob release not releasing
Hi all, My 2008 push in ignition is sticking a bit. You push it in and it pops out a bit so you can remove it.
Occasionally, more and more, you need to push it in a few times before it will motor out for extraction. I cant see how the mechanism works or find a replacement part to look at. Has anyone had this problem? Im thinking of spraying dry lube in but not sure if that's a good idea. |
