| Granola727 |
Jan 19, 2015 06:45 AM |
Automatic trans whining ( fluid ? )
I have a 2001 xc70 recently I have noticed a whining sound from the transmission in the morning. The sound speeds up as I drive faster. The sound disappears after a few miles and everything is warned up. I checked the fluid level but I'm unsure if it's accurate. There is no procedure in the owners manual. I warmed the car up parked on level ground, shifted through all the gears, put the car in park and left it running. When I first pulled the dip stick out there was just barely any fluid touching the stick. I wiped it off and stuck it back in and check again. This time there was fluid up to the hot mark. I did the same procedure three days straight with the same results. Initial check of the dip stick almost no fluid, but up to the hot mark after I put it back in to check again. Any ideas?
Thanks
