P2111 Code - Throttle Control Unit
Hey folks. So I got in my 2003 XC70 this past weekend and immediately noticed it was running/idling very rough and I got a warning message that indicated reduced engine performance and it threw a CEL. My scanner tells me it's code P2111 (throttle actuator control system - stuck open).
I've removed the throttle control unit and it had a fair amount of build-up, but didn't seem like enough to be problematic to me? I removed the throttle plate and thoroughly cleaned everything. I then popped the (5?) metal clips off of the 'control' box to inspect the connectors and gears. The gears were in good shape and I cleaned the contactors.
My question is this; is it worth my time to have done all this and now put the part back on to see if that fixed the problem, or once this occurs does the TCU need to be replaced?
Any and all advice will be very much appreciated!
P.S. Not sure if this helps, but here are the numbers the module had on it:
30650013 (located just below "VOLVO"
02W472 (just below aforementioned number)
I might be of some help...I have a unit 30650013 that was on a car motor tested for marine use....about 10 hours...never on a car only a dyno I am using the bottom end for a project but I am parting out the head and its parts...it is genuine volvo and I can send you pics...when I took the engine apaqrt, I didn't even get my hands dirty...the unit is spotless...I have lots of pics and will even warrenty the part for 90 days...make me an offer and maybe we can help each other...bob....919-740-4698...I do not need this piece and could use the money to finance my project.
Thank you. Since I did not get any replies to my posts I went ahead and ordered a replacement accelerator pedal. I'm hoping to get it installed today and if that doesn't fix the problem I'll certainly be in touch. Thanks!
Good luck!
MFHull
Oct 9, 2014 09:01 AM
treestone27
Apr 29, 2014 07:40 AM
