97 850 erasing the P0733
Old 03-22-2019, 02:25 AM
Patrick Ryan's Avatar
Default 97 850 erasing the P0733
Hello forum.Does anyone have a fix for erasing the dreaded P0733 code.I have flushed the fluid out ( 2 gallons).The flashing is gone.Ive tried erasing them but the code resets after 1 min.when restarted. I just need it off so I can smog it. Runs fine.just need it gone..
Old 03-22-2019, 08:57 AM
runs fine may not be the same as what the code is telling you. P0733 is saying the transmission is slipping (ie the input/output speed readings are out of spec). You can try doing a 2nd or 3rd flush then drive lightly to get emissions, but it sounds like your transmission may need servicing (unless there's a sensor/wiring issue - but there I'd expect other codes to present as well). Any other symptoms or codes? Like with all the 850s, you can also try the shifter row in case there's something up with the PNP sensor then reset the code to see if it returns.
vf91745
10-31-2019 09:53 AM
Chrispy_T
10-15-2013 10:28 AM
95850turbo
05-09-2013 11:05 PM
pell
03-24-2013 06:57 PM
chachouu
06-09-2011 07:59 PM
Quick Reply: 97 850 erasing the P0733
