Sunroof won’t open
Need help-sunroof wont open when hot ok when cold
Hello everyone,
I have been reading about this issue what other people have. Mine is different.
When cold in the morning Sunroof and Map lights work, but when the car gets hot it does not.
The alarm works.when I press it on the remote.
Could someone give me some hints?
Thanks you in advance.
+1 on heat causing a connector, switch or a relay causing a circuit to open up. You'd need to look at the wiring diagram or relay/fuse layout to see where the sunroof and map lights have common wiring/fuses/relays/ground points then test (a can of cold spray or compressed air can help by cooling off a component to see if the circuit closes as the device chills.)
backslide
10-21-2006 04:14 PM
