-   Audio/Visual Electronics (https://volvoforums.com/forum/audio-visual-electronics-26/)
-   -   Bad AM interference (https://volvoforums.com/forum/audio-visual-electronics-26/bad-am-interference-13168/)
Tiberius Aug 14, 2007 03:22 PM
Bad AM interference
I just installed my IPOD adapter into the rear of my OEM stereo, into the changer port. It works pretty good but there is some high pitched whine that comes from the stereo inthe changermode (used for the iPod) AND now my AM stations are coming in terribly! I grounded it to a bolt underneath the glove compartment as the DIY manual suggested. Please help!
S70driver Aug 14, 2007 03:25 PM
RE: Bad AM interference
What kit did you buy?
TheSteelKnight Aug 14, 2007 03:47 PM
Am stations come in clearly?
Tiberius Aug 14, 2007 05:05 PM
USA Spec PA11-VOL IPod Adapter for Volvo S60/S70/S40. The one I got actually says it a "hybrid version" where you no longer have to mess with the dipswitches but you still can. I talked to a friend of mine who thinks that since I wired it into the harness in the SAME port as the power to the radio, its picking up all kinds of interference.
Tiberius Aug 14, 2007 07:44 PM
And to answer the other question..no the AM stations are coming in with lots of static and the FM stations work fine except a couple are always looking for signal...
TheSteelKnight Aug 15, 2007 12:32 PM
errr...sorry bro it was more of a joke then anything else. was saying it like, do any am stations ever come in clearly, cause the majority of them dont. sorry for the confusion.
Tiberius Aug 15, 2007 05:54 PM
No problem man! I should have recognized the joke ha! Today is was working fine. I give up..
TheSteelKnight Aug 15, 2007 11:21 PM
SPARTANS NEVER GIVE UP!!!!!!!!!
cbevis Oct 11, 2007 03:49 PM
I talked to a friend of mine who thinks that since I wired it into the harness in the SAME port as the power to the radio, its picking up all kinds of interference.[/size]
he's right. You need a Radio Suppression Relay in line with the power supply or a Ground Loop Isolator in line with the grounding.
