In car GPS device keep us in safe
More and more new technologies make us live better lives. Especially in our cars, there are too many new technologies to make sure we drive more and more comfortable, safer and safer. Among them, we have to mention GPS device, which helps us to find out the right way from a complicate network. It save our time, energy and petrol. But maybe you don't know that GPS device also could be dangerous because it could expose our locations easily. To protect us not to be tracked down by bad guys, we need GPS jammer. GPS jammer is a kind of new technology device that could block GPS signal, disable all GPS devices in a certain range. To know more about the GPS jammer, let's start from a good GPS signal jammer: the 15 Meters Portable Powerful All GPS Signals Jammer, model number S802012. Absolutely new modern service is available for you with a new GPS signals jammer - a GPS jammer which can block any GPS signal and actually make you perfectly invisible for spies. Some GPS jammers will combine with cell phone jammer and mobile phone jammer, but this is a GPS jammer only, which make sure it could have enough power to block GPS signal.
Different with mobile phone signal jammer, it is a GPS jammer used for cars blocks practically most signals of GPS tracking system and L1, L2 and L5 bands. While using this GPS tracking jammer, you are blocking all GPS signals in 15 meters radius and each GPS tracker will be neutralized in or around your car. The power source of the GPS tracking jammer is an embedded rechargeable battery. The battery works for 2-3 hours. Power adapters are also useful to supply your tracking jamming device directly and turn it on at every time you want. This GPS jammer is a car portable and GLONASS jamming device and its technology was developed in Sweden. It is able to avoid any kind of tracking. This device is easy in usage and handheld, so you have a protection from those who want to disturb your privacy. Features Jammer covers such civil GPS systems as L1, L2, L5 Approximate jamming radius –Up to 15 meters Useful cooler for durable work The rechargeable battery is built-in It includes power adapters for direct supply Rubber/SMA screw antennas Compact size, imperceptible, completely portable Easy usage and guaranteed blocking ability Technical Specification GPS Tracking Channels: GPS L1, GPS L2, GPS L5 L5(1100—1200MHZ) L2(1200-1300MHZ) L1(1500-1600MHZ) Power: 75dbm Operating Zone: Up to 15 m Power Supply: 2 special power adapters/battery Operating Current: about 1100mA Battery Characteristics: Li-ion 8.4V 2600mAh, works for 1-2 hours, charges for 2-3 hours Adapters Description: AC adapter: 110V-250V – DC 12V 2000mA) Size: 111/190x62x35mm Weight: Jammer - 280 g, Full package – 1 kg Temperature: 0 C – 50 C Air Humidity: up to 80 % To know more about it, please come to skybuying.com. |
