CD Interfaciing Cable
Does anyone have the pinout - or better still a cable they will sell me - for the older style 8 pin mini din CD interfacing cable - pins are arranged 3.3.2
Many thanks in advance Update: Well I finally figured it out - seems to be straight throught but....you have 8 pins and 6 wires as two of the wires are double cored and the inner wire is very thin. Take care when you are coldering/ crimping that you dont get a stray wire between signal and signal ground otherwise no signal! |
RE: CD Interfaciing Cable
Did you get this solved? Did you find a plug or cable blank to allow for an after market player to go into the volvo cd changer input?
