-   Audio/Visual Electronics (https://volvoforums.com/forum/audio-visual-electronics-26/)
-   -   SC-901 press-and-hold combinations (https://volvoforums.com/forum/audio-visual-electronics-26/sc-901-press-hold-combinations-41669/)
Veneficus May 15, 2010 11:50 AM
The SC-901 audio system in my 1999 C70 has some button-combinations, which are not all documented in the user's manual.
I'm talking about the ones where you switch off the radio, press and hold a button and then switch the unit back on, giving you access to certain settings.
I know the following:
1 - toggle speed driven volume adjustment
2 - custom equalizer
5 - locality setting
I tried the same with 3, but it gave some weird beep and the whole display came up (all icons).
Does anybody know what happens when you use 3, 4 and 6? I don't want to reset (or lock) everything accidentally (I don't know the radio unlock code).
Pej Mar 31, 2011 01:47 PM
none of them will lock the deck
I've tried all button combinations and none of them locked the deck, so no worries.
4 will tell you the version of your software(which I wish said 2 on mine so it could read CDrs)
6 i dont remember right now.
If anyone figures out a way around the CDr issue please share I'm damn interested in that.
