best place for 120k svc near boulder larimer weld co
Hi, I'm looking for the best place to get the 120k service done on my 2007 xc90. From what I've read, the only things remaining to do is replace spark plugs and timing belt. Also, I've been told by some that I don't need to replace timing belt, but from others, I hear I need to. Any feedback on that also would be appreciated! Thank you!
what engine does your XC90 have? note the V8s have a timing change so no service required. the 5s use the timing belt which is replaced with the tensioner and idler at 120K miles or 10 years - whichever comes first. Also you are scheduled to replace the drive belt and its idler at the same time. So the total 120K service is oil change, air filter, cabin air filter, timing belt/drive belt servicing. After that there's the check list for all the wear items (brakes, suspension, fluid level etc).
