Engine & Internal Chat about beefing up your insides here.
2.5 T oil pan cracked.
Old 08-19-2017, 04:48 PM
RichyRich's Avatar
Default 2.5 T oil pan cracked.
2009 C70. Apparently my wife hit something and cracked the oil pan on one corner. Good thing is was less than 1 block from my house. Looks to be aluminum. Can it we welded in place? Or am I going have to replace it?
Old 08-19-2017, 09:49 PM
ES6T's Avatar
We just replace them, but you can try
Old 08-21-2017, 03:15 PM
RichyRich's Avatar
What about some type of epoxy?
Old 08-21-2017, 03:43 PM
RichyRich's Avatar
Or, what about braising the crack closed while the pan is still on the car? Oil is drained of course and I'll spray it clean with brake cleaner. Wait a few days for the fumes to get out of the engine. Trying to not take the pan off.
Old 08-21-2017, 04:34 PM
ES6T's Avatar
Again, you can try. I've seen various band aids. Never worked.
Old 08-21-2017, 06:55 PM
LittleMushi's Avatar
I have no info on welding your oil pan. Whether you weld it or replace it, I suggest you get an aluminum skid plate, which helps to protect the oil pan. Volvo makes one, as well as IPD.
Old 08-22-2017, 07:08 PM
RichyRich's Avatar
Well, after much thought on the cracked oil pan. I have decided to purchase a new one and replace it. Just ordered it from IPD. Skid plate will be next, just in case...
Old 08-22-2017, 07:28 PM
Great. that's probably the best way to go.
Get the skid plate ASAP, the oil pans are pretty expose, especially in the front. The front of the pan can be easily cracked if you barely hit a parking stop/block.
IPD puts the skid plate on sale a couple of times during the year.
Old 09-28-2017, 04:42 PM
Vovlo07's Avatar
See my post in Thread "IPD pan for sale for Volvo S40 2007", according to IPD's website it should fit your C70 2009, but best to check with them.
NEWVOLVOUSERNEEDSHELP
Engine & Internal
08-19-2016 08:28 AM
svg1234
Volvo C30
29
05-15-2013 08:27 PM
christopherallen
03-14-2009 04:31 AM
Keith Tobberman
11-26-2007 12:35 PM
Quick Reply: 2.5 T oil pan cracked.
