2005 XC90 2.9 ltr awd tr6 high pitch ping when under load/vacuum leaks
2005 Volvo XC90 2.9 TR6 AWD
When I start car it runs very rough. As it warms up it smooths out nicely and runs great. I always allow my cars to warm up before operating. When I drive car and I accelerate to speed up I hear a high pitch pinging coming from engine. When I let off the gas it seems to go away. When I turn off engine I hear a buzzing coming from the passenger side area of the motor, like something is running I guess. I do get a few codes and some codes indicate a possible vacuum leak ? among other things but that is a common factor with them. I do get a brake message in the message center and the engine light has come on. Any ideas Please? Thank you |
The buzzing noise is normal. As long as it turns off within a few seconds after you shut off the car.
If you have a vacuum leak, which is very possible, the first thing to check is all the small vacuum hoses all around the engine for cracks and leaks. Just do that as a matter of routine anyway. The next step is to pull a spark plug and see if it's super bright white and clean, indicating over-heating, which is a symptom of a vacuum leak. Do those two things first, then proceed with further diagnosis. Get back to us with the exact codes. |
Thank you
Did smoke test. Found hole in tube that connects turbos, replaced. Did smoke test again last night; alot of smoke coming out of oil filler Will run codes again today There appears to be a blockage I believe if the smoke is coming out of the oil filler cap Codes prior to locating hole used Vida to run codes ecm-120c ecm120d ecm121b ecm3100 mis fire at start up ecm3210 ecm3220 ecm323d ecm6140 My vehicle started fine this morning, no rough running until warm, which was the case prior to locating the hole Thank you |
Smoke out the oil filler is a problem that is common. Replace that O-ring!! There should be no leak there. This will create a vacuum leak through the crankcase ventilation system. Could be your problem. There is also general service to the Crankcase ventilation system that may need to be performed as well. Do the easy things first, then re-check any new codes. Clear the old ones first. It's not a bad plan to disconnect your battery for 5 minutes then reconnect to reset the computer back to factory settings when you do maintenance like this. Keep at it and you'll get to the solution. It takes patience.
