2007 S60 amplifier problem
I am having a problem with my stereo system on my 2007 S60. I have the premium sound system. The only speaker that works is the center speaker on the top of the dash. All other speakers do not work. I believe it is related to the amplifier which is under the front passenger seat. The problem first appeared after I had spilled a lot of water on the passenger front floor area. I recall once reading a comment from someone that they had a similar problem after also spilling fluid on the front passenger side floor which shorted out the floor mounted amp. I have checked all of the three fuse panels and there are no blown fuses. How do I determine if the amp is blown? Are there any in line fuses I might have missed? Could the problem only be related to the wiring harnesses? I have located the amp under the passenger seat and prepared to remove but wanted some input from other Volvo owners who might have had the same problem.
Thank you,
CAKVolvo.
Thank you,
CAKVolvo.
shimby
Aug 10, 2008 09:53 AM
