2013 c 70 Front oxygen sensor
Google " Volvo 9487150" or go to a dealer web store like Tascaparts.com or a Volvo friendly web site like FCP Euro or IPD USA.
Be ready for sticker shock. Also, why do you think you need a new front O2 sensor? Quite often intake air leaks or exhaust leaks can throw a code that points at the O2 sensor being "out of range".
I had it diagnosed at a shop that does for foreign auto repair but they wanted $388 for the sensor. They wanted that much just for the part.
Would appreciate knowing is this is the correct one? I am a bit of a Gillian mechanically and would be like me to order the wrong part! THANK YOU!
Would appreciate knowing is this is the correct one? I am a bit of a Gillian mechanically and would be like me to order the wrong part! THANK YOU! (Never posted on a forum before either so on a learning curve here as well.)
Here's the link to Tascaparts.com, which is a dealer's web store showing the genuine Volvo part number, fitment and which part numbers are superceded.
https://www.tascaparts.com/oem-parts...sensor-9487150
If the Amazon seller cites its a direct fit replacement using a Bosch part number with a cross reference to the Volvo number, then that's the part they are recommending as the aftermarket replacement.
