940 engine shut down
anybody experienced bizarre symptom??
random 2/3 times a month my 92 940 wagon (non turbo) will shut off with out any warning....i coast off side freeway ..bring to a stop....wait 1/2 minutes...then it starts a runs as if nothing happened for another week or so... check engine light does not light up...... cleaned air flow mass meter, changed distributor cap/rotor....not sure if it is electrival or fuel issue...???[:@] pretty dangerous drive around like this.....local mechanics cannot troubleshoot,,,,since cannot' replicate failure so that they can find cause.......:eek: any ideas ???? tx Al |
RE: 940 engine shut down
It could be anything from sensors to fuel pump intermittent problem, or fuel vapour causing air lock in the fuel line (not very likely for modern cars, though).
Without testing the car myself, I cannot give you an accurate solution. See if Moderator Tech could help you. PM Tech or post a thread with the title like Tech I Seriously Need Your Help!!! JPN |
