Ac & rec buttons flash on start up
94 850 Turbo. Been reading up on thread but still not able to figure out what is wrong. Both buttons light up on starting car. Blower motor does not blow air at all. No hot or cold. Pulled the blower motor and it's fine. Switched out the blower motor resistor and still not working. Any ideas?
If the over-current code is stored - even though the motor works - the solution is to replace the motor.
A work around - sometimes this works. Start with the Climate system off when starting the car. Then slide the fan switch over to a lower speed to turn the system on. .
Yes the fan motor for the heat/ac system. There's a self diagnostic box under the hood that will talk to various systems. This page gives info
https://www.matthewsvolvosite.com/read-codes-volvo-850/
Looks like Climate is terminal #1 in the b (grey) diagnostic box and 411 code is fan overcurrent.
It's not a normal OBD port, that's in the console and PRE 1996 cars does very little. It looks like this, plug the loose wire into the port you want, push the button in a specific fashion and the light blinks codes. or use the old volvo scan tool. What year is your car?
maybe a bad fan resistor (power stage) The right temp sensing fan won't turn off the heater fan.
417 Passenger’s side interior temperature inlet fan seized
418 No control signal to blower fan power stage
419 Faulty diagnostic signal from blower fan power stage
The resistor varies the ground , there's + 12v to the fan all the time. The CCM is not coded to the car, a used one should be plug and play. However the CCM in 99 + cars are tied to the VIN and require a download to make a new one work or possibly a used one from the same year and part number might work.
seeofgreen
Mid West
02-11-2021 07:03 PM
