Engine build
Looking to build an engine for my 1995 850 turbo and I'm curious if I start with a 2000 V70 turbo will it bolt up to my trans and engine mounts.
I'm fairly certain that it will bolt up. However, you have some serious electronics differences between the two engines. For starters, the 2000 engine is wired for an electronic throttle body. Second, the number of sensors increased and I believe that your 2000 has variable valve timing on at least one cam while the old 1995 model doesn't.
This is not an easy switch. |
Originally Posted by tony1963
(Post 457606)
