Engine cylinders
In the C70 turbo engine, are the cylinders number from 1 to 5 starting at the cam shaft sprockets or by the air filter/
From the front of the engine. The end with the timing belt.
A cylinder is the central working part of a reciprocating engine, the space in which a piston travels. Whether you want diesel, petrol or flexifuel, you’re bound to find the perfect engine to suit your lifestyle in the volvo V70 range. It has advanced four-cylinder Flexifuel engine.
