multiple check engine ! p0445 p0448 p0245 p0031 p0136 p0037 p1655
i wife just came back with the C70.... check engine on.
i tried with a generic obd the erase them... but they came back immediatly after i start it. i tried to change my battery with an other car... no good solution ??? please help me ! C70 2001 cabrio OBD code are: p0445 p0448 p0245 p0031 p0136 p0037 p1655 |
RE: multiple check engine ! p0445 p0448 p0245 p0031 p0136 p0037 p1655
You may be able to clear the codes, however, until you actually repair the problems..they are just going to keep coming back everytime you start the engine. From what I read on my scanner glossery..you have several issues in the following areas..
Purge Control Valve Vent Control Turbo Westgate Sol A O2 Cir bank Sensor 2 CVVT Solenoid Maybe TECH can help further..Good Luck and Happy Motoring |
