Numerous codes on 2003 XC70--new ECM??
ECM-928C, EOOO, 510F, 9400, 4050, 400C
SRS-0004, E003 Display reports brake failure, others Add'l diagnostics fail w/ message "Fault in communication with ECU." Suggestions? |
the speed sensors connect to the ABS and Tranmission computer and to the ECU. I'd look into the symptoms of a failed ABS controller board. Not sure about your model year but its a common fault area for 2000 vintage Volvos where the solder joints in the ABS board crack and cause errors and codes.
Google Midwest ABS and RochaTek for details. |
Thanks! I'll look into this.
