P0345
P0345 is a cam position sensor (bank a) fault code. possible causes are the sensor, the wiring harness/connector, a system voltage issue (ie weak battery). When you say the car is not starting, does it turn over slowing or at the regular speed? First thing I'd do is check voltage at the battery then determine if you have a starter issue (including cables/terminals) or simply an issue with the cam sensor.
