SOMEONE PLEASE HELP
Old Nov 3, 2007 | 07:45 AM
markjenross's Avatar
Default SOMEONE PLEASE HELP
I HAVE A VOLVO V40 t4 MY CAR IS RUNNING ROUGH AND SUDDENLY DYING WILL START WEN LEFT FOR WHILE BUT CONTINUES TO RUN VERY ROUGH I HAVE HAD RECENT NEW TURBO COILS FILTERS BT NO CHANGE
Old Nov 3, 2007 | 08:40 AM
Default RE: SOMEONE PLEASE HELP
Like I have said to you many times you need to find out what you are loosing when it dies.
Spark?
Fuel?
Injection pulse?
Then we can help you more.
Old Nov 3, 2007 | 08:55 AM
tech hi sorry im new to all this an keen to d.i.y
how can i tell check.???
can you give me some helpfull advice
Old Nov 3, 2007 | 08:58 AM
You will need to get a fuel pressure guage and connect it to the fuel rail and monitor it while you drive.
You need to get a special tool called a noid light and when it dies connect it to a plug for one of the injectors and see if it flashes when cranking.(That is when it won't start)
http://www.twistingwrenches.com/imag...ls/OTC7602.jpg
That is what a noid light looks like.
Keep the top spark plug covers loose and check for spark when it won't start.
Old Nov 3, 2007 | 09:11 AM
thanks
it will start but just wont run smooth or pick up revs
Old Nov 3, 2007 | 10:47 AM
someone has recommended cam sensor?any advice?
Old Nov 3, 2007 | 12:37 PM
Maybe but that will usually throw a code.
Also make sure no fuses under the hood in the fuse box are bad.
If there is one blown let me know before replacing the fuse.
Old Nov 3, 2007 | 02:05 PM
ill check in morning tech thanks for help?is there any way to test if sensor is bad?where are fuel relays situated in t4?thanks
Old Nov 3, 2007 | 05:13 PM
The nois light will help to tell if the Cam sensor is bad.
I believe the fuel relays are in the fuse panel under the hood.
Old Nov 4, 2007 | 02:19 PM
some1 has put it to me very gd chance it is egr valve would this cause this??
Old Nov 4, 2007 | 07:47 PM
I doubt it.
mlissmelissa
Dec 22, 2013 03:07 PM
Ozali1986
2001-2013 model year V70
Jun 21, 2013 04:00 AM
ColbyS80
Mar 29, 2012 06:06 PM
iluvjenin10
Apr 27, 2010 04:40 PM
Torkk
Dec 12, 2007 03:02 PM
