Typical V50/S40 Evap Drain/Roof Drain problem, with a twist
Hello all,
I have a 2007 V50 T5 and recently had the typical problem with water pooling in the rear passenger floor. I figured it was either the AC evaporator drain hose/plug or the sunroof drains. I took all the carpet and foam out of that side and got all of the water out of the bottom (gallons). I cleared the sunroof drains and they appear to be working well after testing. I've tried clearing the evaporator hose and plug - as far as i can tell it is clear. But i've noticed when my AC is running now, there is still some water dripping from somewhere slightly further forward than the hose. Do I have an bigger issue here, or is this just excess water that has built up in the AC box that will slowly drain out through the hose? Any Suggestions |
