Volvo 850 alarm/horn. Bushings question too
Old Aug 18, 2010 | 07:47 PM
Jbthomas921's Avatar
Exclamation Volvo 850 alarm/horn. Bushings question too
I have a 97 glt and the horn works when I have the key in the car when when I hit the panic button the lights flash but no horn. Is it the alarm relay sticking or something? Also does anyone know if you truly need a hydraulic press to put lower control arm bushings in? I want to do it myself but I can't if that's the case and the book said I need it
Old Aug 19, 2010 | 07:36 AM
There is a seperate horn that is round that operates the alarm. They have a nut on them that comes loose sometimes. The nut can be adjusted or tighened if it's still there. You may have to replace it.
As for the control arm, search the 850 section for the answer. You may want to try the frequently used threads post.
Old Aug 19, 2010 | 05:43 PM
Ok, I found t and it was loose, but I'm guessing I need a new one because it is just kind of clicking a little now
Old Aug 19, 2010 | 05:54 PM
I took the bolt and round metal price and cleaned it all and it started working! Very happy thanks
cambraj@verizon.net
Feb 10, 2021 08:09 AM
gfreeman9mm
Jan 24, 2020 02:05 AM
pancho
Nov 6, 2014 03:19 AM
Platinum52
Jul 17, 2009 07:33 PM
JimBee
Feb 5, 2009 07:39 AM
