Volvo 850 front hood cable broken can't open my volvo is right hand drive
I saw some pictures of removing the turn signal light to access to open the hood which signal light should I remove the right or the left I am confused please help thanks.
search the boards as there are some older threads that talk to this specifically - but my recall is to start with the driver's side as that will open the right side as well.
The cable across the front would originate on the drive side. At least it does on left hand drive cars. So it is possible to open the hood on a left hand drive car from the left park light. I would assume for you the right would do it. If you pull both park lights it should all be obvious.
