Volvo Cassini alloys won’t fit v70
Old 07-02-2018, 08:12 AM
Default Volvo Cassini alloys won’t fit v70
Hi friends im a new member and a convert from vag to Volvo..I have purchased some 17inch Cassini wheels but they won’t fit my v70?? My v70 hub diameter is slightly bigger that the diameter of the wheel. Was wondering if there’s any way of getting them to fit using adapters..
Old 07-04-2018, 10:19 PM
Moderator
Older Volvos uses a 5x108 hub with 65.1 center bore, newer V70s use a 5x108 with a 63.4 center bore. Its a whole lot easier to put the 65.1 center bore rims on a newer Volvo since all you need to buy is a 63.4 to 65.1 hub centering ring. Going the other way would require an adaptor plate which would mess with offset and probably be expensive. You didn't mention which year V70 you have, but it you are trying to put new rims with the small center bore on an older car, best solution is to sell them and buy ones that fit. If you have a newer V70 with the smaller hub, you can easily find the hub centering rings on Ebay/Amazon etc.
Old 07-05-2018, 01:20 AM
Default Thank you
Thanx for the replyy Volvo is the old one and bigger hub..will get rid of the wheels.
thanx for your help
Dean23
07-01-2018 10:45 AM
adventure boy
07-23-2009 08:01 AM
Ian2000t
12-14-2008 03:57 AM
lanciak66
07-07-2008 01:16 AM
gifthanks
11-18-2007 03:46 PM
Quick Reply: Volvo Cassini alloys won’t fit v70
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
