Volvo xc90 no electrical
Hi I have a Volvo xc90 which the battery ran flat after charging the battery when ignition is turned on the engine light flashes a few times but no power to anything besides hooter,fuel pump and boot light.please help asap
did you check for blown fuses? did you check the battery voltage to see if it retained the full charge?
Yes only fuse I found blown is alarm siren fuse..battery voltage is sitting 13v..also noticed last night that tail lights indicates that light are on but head lights is off and brake light works
