cargo area upholstery material
You can call the dealer and see if the material is available in bulk. If not, the only choice you have is to see an upholstery shop who can source something that is similar. There are many products out there that are durable enough for automotive interiors that would be nearly identical.
Thank you, Tony......It had been a while before anyone responded to my query, and in that time, I found a supplier of this thin, unbounded material that is used by the auto industry to cover those trunk/cargo areas. The place is called "Texas Fabrics & Foam Inc." Its on the net for anyone needing this type material. Regards, Ric Lang
sundance
Oct 2, 2009 06:32 PM
