Interior What have you done to the inside of your ride? Customized it? Kept it super clean? Talk about it here.
overhead light assembly
Old Sep 27, 2011 | 05:21 PM
Lulumike's Avatar
Default overhead light assembly
The overhead light assembly on a 1994 850, (with push buttons to turn on and off, automatic lights when doors open, so on): how does it come off? There are no screw holes, places to wedge a screwdriver, so on. I don't want to break anything.
Old Oct 23, 2011 | 10:00 PM
rrochell8's Avatar
Pry off the light lenses. Small screwdriver for that. There will be two screws inside. Pops right after that.
Old Oct 24, 2011 | 01:03 PM
Lulumike's Avatar
Thanks rrochelle8, that makes my life a bit easier.
Old Nov 7, 2011 | 07:57 PM
The screws are T-10's. You gently pry off both of the lenses and then take out the two screws. The housing itself is just held in place with some spring clips and you gently pull down on the plastic and it will pop out of the headliner. There is one electrical connector that has a retaining tang on each of the short ends. I had a bit of trouble as I could only see the one tang in the dark and couldn't get it apart until I grabbed a flashlight and looked close. I just upgraded mine to LED's this evening. If you're doing that the positive is the copper strip that runs to the bulbs. The black wire running from the socket is the negative. I soldered mine in but next time I'd get the ones with the adapters.
The one in the cargo area (wagon) is a "festoon" style so that was easier as mine just dropped in. Now I have extras but for two fifty a bulb it's wonderful light.
foldingchariot
Dec 18, 2013 03:24 PM
liweih21
May 17, 2013 04:29 AM
theboneskes
Dec 20, 2011 11:02 PM
vokseniu
Jul 21, 2011 08:58 AM
xjflexer
Apr 7, 2007 06:31 AM
