For Sale: Snabb 3" Turbo Intake Pipe for Volvo 3.0L engine + Snabb Engine Cover, New
Engine - Intake/Fuel
  • Engine - Intake/Fuel - For Sale: Snabb 3" Turbo Intake Pipe for Volvo 3.0L engine + Snabb Engine Cover, New - New - 2007 to 2016 Volvo All Models - White Lake, MI 48386, United States
    Sold
    $360
    • OBO
  • Location White Lake, MI, 48386, USA
  • Condition New
  • Compatibility
Make Model Year
Volvo Any Model 2007 - 2016
Brand new, never used Snabb 3" Turbo Intake Pipe and Snabb Engine Cover for Volvo 3.0L
Fits most 3.0l Volvo's:
  • 2011-2016 Volvo S60 T6 (3.0L Engine)
  • 2015-2016 Volvo S60 Polestar (3.0L Engine)
  • 2011-2016 Volvo V60 T6 (3.0L Engine)
  • 2015-2016 Volvo V60 Polestar (3.0L Engine)
  • 2007-2015 Volvo S80 II T6 (3.0L Engine)
  • 2008-2016 Volvo V70/XC70 III T6 (3.0L Engine)
  • 2010-2016 Volvo XC60 T6
List price $399.95 for turbo intake pipe, $189.99 for engine cover
Asking $360 + shipping for everything
*** The stock 3.0L T6 engine cover will not work with this pipe, needs Snabb engine cover.
See
M-000114-Volvo 3.0L T6 Aluminum Engine Cover
www.snabb.us
https://www.snabb.us/3-Turbo-Intake-...60-_p_224.html
Turbo Intake Pipe, 2011+ Volvo S60/V60 T6, S80II T6, V70/XC70 III T6
ViVA Performance specializes in performance and maintenance car parts and accessories for BMW, SAAB and VOLVO vehicles
www.vivaperformance.com
From Snabb website:
 Our 3.0L T6 turbo Intake Pipe does not allow for the factory plastic engine cover to be installed. We have designed a custom made aluminum engine cover that will work with the factory mounts/mounting bushings. This cover is an accessory item to the P3 T6 intake pipe and cannot be installed with the factory intake pipe.
Our lightweight aluminum engine cover is designed to mate up to our 3" P3 3.0L T6 intake pipe. Our .125" aluminum cover, in combination with our 3" intake pipe, is a great way to dress up your engine bay and make your car stand out from the crowd. Our cover reuses the stock engine cover mounts for easy installation and ensures a quiet vibration free engine upgrade. Lightweight aluminum also dissipates heat much faster than insulated plastic reducing heat build up at the coil. Description
Snabb is proud to announce the release of the worlds first production 3" intake pipe for the 3.0L T6 P3 Polestar S60's, 3.0L T6 S60's and 3.0L T6 V60's.
When you've spent money for the premium Polestar upgrades and are buying the best performance car that Volvo makes, why settle for the restrictive stock factory intake pipe that comes with it? We've spent months developing and perfecting the 3" turbo intake pipe to perfectly compliment the high output Polestar S60's and R-Design T6 cars.
When you buy a Snabb intake you eliminate the restrictive OEM fresh air pipe that runs from your mass airflow sensor to the turbo. Our performance fresh-air pipe flows better, and looks better than stock. The factory-stock fresh-air pipe has wide flattened section, a corrugated plastic coupler, smaller, restrictive diameter and includes a power robbing resonator. These three factors reduce airflow and create a restriction to the turbo.
Our objective is to give you the absolute highest quality kit available that is right at home Volvo Polestar. We have sourced the best quality reinforced virgin silicone connectors, precision 3" in-house fabricated and TIG welded aluminum pipe. Our 3" pipe includes an integrated (easy to install) bracket, factory fitment bosses, replacement breather hose, TCV relocation bracket and marine grade 316 stainless steel clamps. Visually you will make a statement with the Snabb intake pipe. People will know something is different, and special when you open the hood. If you want something more stealth then we have a black texture powdercoated kit available as well.
PLEASE NOTE the stock 3.0L T6 engine cover will not work with this pipe. We recommend you get the Snabb Aluminum engine cover to compliment your intake pipe and complete the installation. The engine cover is sold separately and has several finish options.
This kit includes:
(1) Polished 3" aluminum pipe with vacuum barbs, breather boss, and easy to mount welded bracket
(2) Heavy duty Silicone connectors
Replacement Breather hose (black)
5mm silicone vacuum line for TCV (black)
TCV bracket
mounting bolt
(4) 316 Stainless steel (marine grade) ABA worm clamps
Installation instructions
PLEASE NOTE the stock T6 engine cover will not work with this pipe we recommend you get the Snabb Aluminum engine cover to compliment your intake pipe and complete the installation. The engine cover is sold separately and has several finish options.
Snabb Engine Cover: Description
