1992-1997 Volvo 960 Intake Manifold Sleeve
Hello -
I have a cracked intake sleeve. Do I have to use the OEM or can I use an aftermarket silicone sleeve? If so, who would be a good manufacturer? Also, if I have one that is cracked and bad, should I replace all of them? I put permatex to fill the crack in the one and that has solved the problem for now. If I have to replace all of them, do I have to rip out the entire intake or can I sneak them in? What specific hose clamp can I use or heat temperature zip tie to seal the ends? I have a 1993 Volvo 960. Thanks in advance for your advice! |
