C30 engine growl when turning right
I have this loud growl when turning right at any speed. Any idea what it is?
I'd suspect either a motor mount/transmission mount, an axle or a wheel bearing. Does the same noise happen if you shift into neutral then turn? More noise if you apply power when turning?
Thanks for responding. The noise is not present when at idle and only appears when driving and turning right. A motor mount sounds like the best assessment.
