Friendly info needed.
Hello everyone. My name is Martin I'm a retired disabled veteran and proud owner of 2001 Volvo v70 2.4t. It's my first and won't be the last. I'm a car junkie. My question is will Lexus wheels fit on my car the rim is 17x7.5 50mm offset lug pattern is 5x114.3 without wheel adapters?
https://cimg7.ibsrv.net/gimg/volvofo...2f70a9a708.jpg |
Short answer is No, won't fit.
Longer answer: A 2001 Volvo uses a 5x108 wheel with a 65.1mm center bore. The offset (ET) will vary by rim width but should be in the 45-50 range. Volvo's are "hub-centric" meaning the rim's center bore fits exactly to the hub to center the rim. |
Thank you kindly for your reply.
