240 Volvo high idle
It could be your throttle body is worn out and leaking through the butterfly axle shaft, or the butterfly is misaligned in the throat. The engine can't idle high unless it's getting air. It's coming from somewhere, and it's going through the MAF. Could your throttle linkage be binding or out of adjustment?
I'm not sure which one is which, but some of the older cars had a simple idle adjustment screw. It didn't use a throttle regulator like newer cars.
tgaulkin
11-27-2013 03:29 PM
