-   Nitrous, Super Chargers, & Turbos (https://volvoforums.com/forum/nitrous-super-chargers-turbos-23/)
-   -   Boost Control (https://volvoforums.com/forum/nitrous-super-chargers-turbos-23/boost-cntrol-345/)
DrewG1998 May 24, 2004 09:43 PM
Boost Control
I've been looking into getting an electronic boost control for my 1998 S70 T5. Does anybody have one, and if so do you have any suggestions on which to buy, and what psi to run?
Turbo Jul 13, 2004 05:17 PM
Boost Control
TurboXS makes a boost controller that fit's turbo volvo's just fine, best boost to set is between 12 and 16<FONT face="Courier New, Courier, mono">.</FONT></P>
S70driver Jan 21, 2006 07:46 PM
RE: Boost Control
Well on the T5 atock your running like 10PSI right? I would up it to like 15 PSI at the most.
Also I do reccomend that you do not use a MBC. I would get a ECU upgrade, which is a lot better and can control the boost better.
gdogg16 Apr 25, 2006 12:42 PM
RE: Boost Control
ORIGINAL: S70driver
If he's going to be using a electronic boost controller, how is he going to use a MBC and why?!
S60T5 Apr 25, 2006 05:45 PM
RE: Boost Control
ORIGINAL: gdogg16
ORIGINAL: S70driver
He said not to use an MBC, so there is no explanation of how to use it. But who really cares as the original topic is over one and a half years old.
gdogg16 Apr 26, 2006 03:30 PM
RE: Boost Control
That's exactly my point, why would you use both an EBC and a MBC?;)
S60 R Apr 27, 2006 01:21 AM
RE: Boost Control
ORIGINAL: gdogg16
He said not to use an electronic or manual boost control. What he and others have said is to get an ECU upgrade for newer Volvos.
gdogg16 Apr 27, 2006 03:05 PM
RE: Boost Control
ORIGINAL: S60 R
ORIGINAL: gdogg16
AHh you are correct. Nothing wrong with using a MBC or and EBC. It's only on Me7 or Me9 cars that really you just can't use either of them on. There are a lot of benefits from runing a MBC, smoother boost curve etc.. Just don't do it without a guage..
CSudhoff May 4, 2006 12:13 PM
RE: Boost Control
Do NOT get a manual boost controller....one word... JUNK!...save your $ and pick up a good Electronic Boost Controller. On a MBC there is no selonoid to control the wastegate, often leading to boost spikes etc... save your $ and your $ EBC or ROM tune!
Check out Greddys Profec B Spec II manual boost controller, you can pick one up for around 330.00 new. Great EBC for the $!
