Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
TD04h-13C oil port question
Old 09-08-2011 | 10:22 PM
jared8783's Avatar
Default TD04h-13C oil port question
Ok so here is whats up. I own a 1990 1.6 miata.
I recently bought a Td04h-15g (greddy turbo) with a broken shaft and a rebuild kit. So I did some searching and found some turbo's with compatible shafts. I ended up purchasing a blown Td04h-13c off of a volvo (and yes they are both flatback compressor wheels so the rebuild kit will be compatible).
Now I have already test fitted and the chra fits the greddy exhaust housing perfectly. I intend on using the 13c wheel since it was already lined up with a shaft so i will not have to rebalance. I know its smaller but maximum performance is NOT my goal. A budget learning experience is what I am looking for here. So long as it will hold a steady 5-6 psi I will be satisified. I know alot of you guys feel this turbo is restrictive but I got it on a 1.6 instead of a 2.3 plus when I compared exhaust housings the one on my 15g (which I will be using) is considerable bigger than the one on the 13c.
So now to my question. As you may already know the chra for the greddy turbo has an oil inlet on top and an outlet on the bottom. Now the chra on the td04h-13c has the obvious outlet on the bottom. It came with a pipe boltet in the side, and on both the top and the other side it has threaded holes.
So do i just plug off the two holes on the side and stick my oil inlet from the greddy on the top? Do I just plug up the holes with bolts and threadsealer?
The below photos are as follows
The first photo it the 13c wheel on the greddy chra. See that gap? Thats why I dont want to just run it like that.
The second photo is the 15g wheel on the greddy chra. This photo is for comparison purposes so you can see the gap is much less.
The third and fourth photos are the td04h-13c chra. See the Threaded holes I am talking about?
The last photo is the compressor housing for the td04h-13c. It has a built in bypass valve. Something you guys probably already know. Another reason I want to run the 13c, I won't need to purchase a bypass/blow off valve.
Thanks for reading
This specific turbo is proving very difficult to find info on.
Jared
Attached Thumbnails TD04h-13C oil port question-100_1011.jpg   TD04h-13C oil port question-100_1013.jpg   TD04h-13C oil port question-100_1016.jpg   TD04h-13C oil port question-100_1017.jpg   TD04h-13C oil port question-100_1018.jpg
850turbodriver
03-07-2016 01:49 PM
jared8783
09-07-2011 07:46 AM
jared8783
09-04-2011 06:01 PM
SaabGoblin
12-14-2010 09:12 PM
hdz123
08-03-2010 02:07 PM
