How long does your average turbo last?
Im buing a 1998 s70 t5 with 138000 miles on it and was wondering how long a turbo in this type of car usually lasts? Is it limitless?....My 1994 850 Turbo's turbo with 216000 still works but definetly runs at about 1/2 the pressure it used too.
-seth
-seth
RE: How long does your average turbo last?
i also have a question about that. since the S40 has a "low boost" turbo, wouldn't that lengthen the life some? I mean, you're not dealing with the typical high pressures of a high performance car's turbo. And how is it that the turbo is "low boost" in the first place?
Alot of people say the turbo's go out pretty fast on these cars.
But as long as they are serviced correctly they will last a long time.
I have seen alot of cars with atleast 100k on the original turbo.
Not sure why Volvo has the boost low. I really never checked how much but would have to guess about 7 PSI or so.
It is all controlled by the ECU.
just from my limited experience. the average turbo needs to be replaced or rebuilt every 60-90k miles. depending on the pressure it has running. Some will go twice that long with no problem. but still wont work as well.
Take toyota supras for example. just like on this board where at 60,000 miles change the timming belt, they are the same for do something with the turbo. see everything has its little quarks.
I drive an s40...its low pressured because the 12t turbo is tiny and is made to take high pressure for too long. Stock the 12t comes around 7-8 psi. I bought a boost controller and have it running 11 right now and its a world of a difference. These 12t's can last as long as the car as long as they are treated respectfully. It's usually the drivers that kill these turbos.
Anyway, Seth, if the car was maintained and boost kept below 12psi or so, stock Volvo turbos can readily exceed 150k miles. Of course that lifespan is affected by boost level to a great degree. Turbo shaft speed and RPM tends to increase proportionately with boost level, and turbos that are seriously overspooled will tend to require exorbitant RPM to eek out the last pound or two of boost that the driver wants.
To inspect your turbo, you can always stick your hand in the compressor inlet and cop a feel for play and excess oil near the inlet. Those will give you telltale signs of its impending future.
As far as your personal experience goes, if your turbo puts out half the boost it used to, it's either seriously messed up, the wastegate actuator's return spring has weakened significantly, or you have a massive boost leak. If it's a boost leak, your turbo could very well be spinning twice as many revs as the boost level you're receiving would dictate, but since half the boost it's putting out is just going through a crack in a boost hose, you think it's only pushing out the amount of boost on the guage. That can kill a turbo very quickly.
Turbos don't typically just slow down and eventually stop. They usually go from working fine to failing catastrophically, if severe oil blowby doesn't kill them first.
ORIGINAL: gordon368
lol if something goes wrong with the turbo lets say in the s80 t6, will it still drive ok?
In summation: Don't drive with a blown turbo unless you're stuck in the desert or something.
The previous owner of our 1990 740 Turbo rarely changed the oil, and it clogged the inlet and return lines, the turbo finally broke in half, The compressor turbine was sitting loose in the inlet side, and the impeller was turning independent. She finally parked it when this happened, due to the smoke.
The entire exhaust system was full of oil, as was the intake.
It took a new turbo, and alot of driving, but it finally has stopped smoking.
#17
#20
