North East ME, NH, VT, MA, RI, CT, NJ, NY, PA
Lucas Stop Oil Leak in ATF Fluid
Old 11-24-2017, 04:58 PM
Amk201's Avatar
Default Lucas Stop Oil Leak in ATF Fluid
Inatead of adding the Lucas Transmission Fix I added about 4 ounces of Stop Oil Leak in the ATF reservoir.
2003 Volvo S60, 2.4L Turbo with 199k. No transmission issues before adding the incorrect fluid aside from a slight stutter into 3rd. It's been doing this hat since I owned it (6 years).
No known transmission fluid changes before I bought it. How screwed am I?
Old 11-24-2017, 09:00 PM
if you are concerned about adding gunk to the transmission, you should simple do a drain and fill with the correct fluid and see if that changes anything. Did you check the color and smell of the fluid before the additive?
Old 11-24-2017, 09:29 PM
Amk201's Avatar
The color is not deep red and smells not so fresh. I don't know if a service has been performed before i
bought it with 115k. I've had mixed responses on performing a transmission service from people, especially with 199k on it now--if it wasn't done before don't do it now they say. Catch 22 now. Do it because 4 ounces of Stop Oil Leak is in it or do it because of the color and smell, ignoring the high mileage. Or both.
louiebay
06-04-2013 11:28 PM
gjcluttrell
08-13-2012 11:59 PM
Scott6
09-15-2008 06:20 AM
tech
02-05-2008 08:26 AM
vetalbig
01-23-2008 02:33 AM
Quick Reply: Lucas Stop Oil Leak in ATF Fluid
