April Is National Car Care Month (USA)
April is National Car Care Month and I encourage everyone to take a walk around their vehicle and take a look at the common maintenance areas, many of which are quick, do-it-yourself (DIY) automotive maintenance items.
1. Tires: Check tire pressure, check treadwear, is it time for a rotation? Your correct tire pressures are listed right on the tires and on a sticker inside your driver door.
2. Bulbs: Check for any burnt-out bulbs - especially center/high brake lights (which seems to be an epidemic in the USA).
3. Fluids: Check all fluids under the hood. Most reservoirs have clear markings. Also check your oil change sticker to see if you're due.
4. Air Filters: Check your engine air filter and your cabin air filter. Replace if necessary. Yes - many vehicles have TWO filters which should be changed every 6-12 months depending on your driving habits and climate.
5. Windshield Wiper Blades: Inspect and replace your windshield wiper blades taking note that most should be replaced every 6-12 months.
Depending on your automotive maintenance skill level, there may be other things you should inspect/check/replace.
National Car Care Month serves as a reminder that vehicle maintenance leads to safer vehicles and safer roads as well as a more satisfying driving experience. Use this as a reminder to take a few minutes with your vehicle!
Jeff
President
Wipers123.com
Good Luck!!
Jeff
President
Wipers123.com
Good Luck!!
For my Volvo V70...................
Tire says 44 PSI and door says 35 PSI?? What to do?!!!!
It's a Volvo, I replace bulbs weekly!
There's oil everywhere!
Where's that dead mouse come from?
Check the one's on the headlights too!
For my Geo Metro.....................
Tires are hyper-inflated to 50 PSI
All lamps except headlamps converted to LED.
No cabin filter, just fresh air from the holes in the floor.
My wipers are in the trunk until needed.
1. Tires: Check tire pressure. Your correct tire pressures are listed right on the tires and on a sticker inside your driver door.
4. Air Filters: Check your air filter and your cabin filter. Replace if necessary.
volvie!
West
03-28-2009 04:03 AM
