2003 8.1 stall when starting
I have an issue with my 2003 Formula with 8.1’s . When I start them ( cold ) the port engine stalls unless I run the rpms to 800-1000. And let it run for a while . Then once warm , she runs like a champ. I cleaned the spark arrestor, changes the plugs ( they looked fine but put new in anyways). I’m wondering if the MAP sensor needs replacing? |
Why would you think the MAP sensor needs replacing? Did you measure the resistance of the engine coolant temp sensor?
