Penta Discuss Volvo Penta Marine Machines Within.
AQ120B missing distributor - compatible with 125/140 etc?
Old Apr 3, 2016 | 06:33 PM
niftyg's Avatar
Default AQ120B missing distributor - compatible with 125/140 etc?
First post! Proud new owner of a AQ120b.
Just got a project boat that was sitting for a few years. It is missing the distributor as someone was working on it previously and it got separated.
I'm looking to pick up a used one off of ebay, but there are none available for the aq120. Most part numbers seem to be the same across aq125 131 140 etc.
Would a distributor from models above be compatible with this motor?
Also, would a car distributor with vacuum advance be compatible if I plugged the hole, or does it need a separate advance mechanism the vacuum one is lacking?? (I know I know, safety issues)
One last question , there is a "drip catcher" attached to the carb. Should anything be covering that?
Thanks!! Hope someone with experience with these motors chimes in
MattyXXL
Jun 2, 2011 12:08 PM
zloetakoe
May 28, 2011 07:29 PM
hockey2
Apr 20, 2008 10:13 AM
dlennox2001
Penta
Feb 8, 2006 06:44 PM
dlennox2001
Penta
Feb 8, 2006 06:25 PM
