AQ125A Engine & I/O Prop Problem
Hello,
I'm a new member here, and I have a prop problem that I'm stuck on. This is an I/O with relay controls to raise & lower the prop. The prop will not raise & lower. I have changed the relays but all it will do is click when I hit the prop switch. Any ideas of what to check out next? Help! Thanks! Joe |
RE: AQ125A Engine & I/O Prop Problem
do u have 12volts?
make sure because if u do not then the motor will not raise also these guys here http://www.coastsidefishingclub.com can help |
Sounds like you and I have the same problem. I have an AQ130C I/O. I'm not quite sure what "relay controls" are. I can also hear it click and make noise but nothing happens.
Mike Portland, OR |
If you have someone operate the up/down switch while you go to the back of the boat looking at the outdrive from outside of the boat you will see the plunger that moves the drive up and down. try to take a flat tip screw driver and wedge it between the round plunger and the frame to help it move, then lubricate it.
Sctlny |
